Lights
Modified on Mon, 2 May, 2022 at 2:29 PM
D5 Render provides six types of light sources: Point Light, Spotlight, Strip Light ,Rectangular light,Stage Light and Projector.
Click the corresponding icon button in the navigation bar to place it in the scene, or use the shortcut keys  1 , 2 , 3 , 4  to quickly place Point Light, Spotlight, Strip Light and Rectangular Light, respectively.
Meanwhile, Stage Light and Projector are advanced light source functions, which need to be added to the widget before they can be used.Go to Menu > Preference > Widget to activate Projector, then it can be inserted into scenes from the Navigation bar > Add lights.
Overview of light types
Point Light
A Point Light emits light in a similar manner to a real-world light bulb, from a point in space, emitting light uniformly in all directions.
Spotlight
The Spotlight emits light from a point in space, within a specific cone angle.
By default, spotlights are emitting light uniformly in the cone. You can also control the distribution of light using ies files. D5 Render comes with 6 ies files, or you can import custom ies files.
Strip Light
A strip of rectangular light that can be further adjusted in length and width, using Barn Door parameters to control the directionality of the light.
Rectangular Light
A rectangular planar light source of specified width and height dimensions, used to complement or simulate any rectangular area of luminous objects, such as top lighting fixtures, etc.
Light source parameters
When we select the light source, the corresponding inspector will appear on the right side. First, let's introduce the parameters that are available for all four light sources:
Common parameters
Duplicate
Select a light and click the Duplicate button, a copy of the light with the same parameters will appear at the mouse cursor, click to place it into the scene. Hold Shift and drag the red, green or blue axis to copy along the axial direction.
Focus on
Click the Focus on button and the camera will move in front of the selected light source.
Reset
The position of the light source in space remains unchanged, and all others are restored to the default parameters, including the rotation angle.
The following five parameters are also common to all four light sources:
Intensity
the luminous intensity of the light source, in cd (candela, candela), the maximum intensity can be 8000000.
Attenuation Radius
Limit the influence range of the light. Within this range, the light decays according to the inverse square law, beyond which the light calculation stops. The size of the spherical range can be visualized by the wireframe.
Visible in Reflection
Controls whether the light source appears in the material reflection, and the "Blend Amount" control allows you to adjust how much the light source affects the reflection.
Temperature
Scientifically set the color of the light. The unit of color temperature is K, Kelvin. Low color temperature such as: 3000K light source appears yellow. Light color temperature is 5500-6500K, is considered to be the "white" light. High color temperature such as: 8000K light source appears blue.
Color
Freely specify the color of the light.
Next, we explain the parameters specific to each light source:
Point Light
Light source radius
Control the radius of the imaginary point light. The radius of the light affects the softness of the shadow edges, the larger the light source, the softer the shadow edges.
Spotlight
IES
Use the 6 ies built into D5, or choose a custom ies file to control the light distribution of the spotlight. A light source placed close to a wall will shine a specific shape on the wall. Click + Customize IES to add a custom ies file.
Cone Angle
Controls the cone angle range of the spotlight's light-emitting cone. Note that if an ies file is used while adjusting the cone angle parameter, ies lighting outside the cone angle range will be clamped.
Light Source Radius
Same as point light source radius. The radius of the light affects the softness of the shadow edges.
The reason for putting these two together is that they are both essentially rectangular lights, the only difference is that the initial parameters are set differently.
Strip Light is a rectangular light with a large initial aspect ratio (long strip) and a certain Barn Door Length (Means that it will emit light in a specific direction).
The Rectangular Light is a planar light source with equal initial length and width, and a Barn Door Length of 0.
The parameters unique to these two light sources are the "Barn Door" parameters.
Barn Door Angle
The angle between the imaginary "Barn Door" plate and the direction of the light's normal, the value range is 0 ° - 90 °. Smaller values focus the light; at 90°, the Barn Door is wide open and the wireframe in the viewport provides a visual representation of the "Barn Door".
Barn Door Length
Controls the length of the imaginary "Barn Door", ranging from 0-100. Larger values focus the light, and the wireframe in the viewport provides a visual representation of the "Barn Door".
Light source visibility control
Use the shortcut  L  or the "Light Source" button in the upper right "Display Mode" to toggle light carrier icon. Toggling carrier icons does not affect light rendering.
To temporarily turn off a light source, turn off the visibility of that light source in the scene resources list on the left (click on the eye icon) :
Note: All light sources themselves are not visible to the camera. The lighting of the light source can only be seen when there is a model near the light or when the fog effects are turned on.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
