What formats does the local library support for importing files?
Modified on Sat, 28 May, 2022 at 1:22 PM
1. All models in the local library need to be in d5a format
  - D5 converter can export model files with materials in d5a format
  - Model files that support direct reading (.skp .3dm .abc .fbx) can be imported into D5 through the "Add to local" button in the model "Inspector" panel. After adding the model to the local library, the model format will be automatically converted to d5a format.
2. All the materials in local library should be in d5m format
  - The material template, material map, and material parameters of the current material will be saved as a d5m file by using the "Add to local" button in the "Inspector" panel of
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
