How to control the bump effect of a material?
Modified on Sun, 8 May, 2022 at 8:30 AM
The use of normal mapping will give the material surface a bumpy visual effect without additional modeling effort.
In D5 Render, if the normal map is empty, D5 Render will also automatically generate the normal information based on the base color map to give the material a bumpy appearance.
Adjusting the normal parameter can enhance or diminish the normal bump effect. If you enter a negative value, you can flip the bump effect.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
