Adjusting the UV parameters of a material has no effect
Modified on Sun, 8 May, 2022 at 8:16 AM
The UV of the material is currently divided into two parts: the individual UV and the main UV.
- If a material parameter's map has individual UV turned on, it has independent UV parameters. You can further stretch, offset, rotate, or use triplanar to repair it.
- If adjusting the main UV has no effect, it is likely that the switch fo3r individual UV is turned on in one of the parameters.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
