What is the depth parameter of the water material?
Modified on Sun, 8 May, 2022 at 8:40 AM
The depth parameter makes the water material in D5 Render closer to the real-life physical representation and is related to the depth of the container. From the diagram, you can visually see the effect of the depth of the container on the performance of the water material for the same material parameters.
 The color of the water also changes with the depth of the container, which is equivalent to automatically attenuating the light intensity below the water surface according to the depth.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
