Why does the AI-processed image lack quality/show no noticeable effect?
Modified on Sun, 27 Apr, 2025 at 2:46 AM
Hello, if you find that the image quality after AI processing is not satisfactory, please try increasing the resolution of the renderings and adjusting the Weight parameter accordingly before re-running the AI task.
For more function guidance, please refer to: How to use AI Post-Processing? | User Manual
- If the differences between the original and AI-processed images seem minimal
There are two known factors to consider:
  • With AI Enhancer, the same enhancement weight tends to produce more noticeable changes on lower-resolution images.
  • Characters smaller than approximately 120x200 pixels may be excluded from processing by AI Enhancer.
Solution: Please increase the output resolution to ensure all elements are detected.
- If you have any additional feedback or suggestions regarding AI effects
Please contact us with the following:
  • The original images (before and after AI processing)
  • The time when you started the AI task (including your time zone)Your log file
This information will help us further optimize the AI feature.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
