Why does the output not match/differ greatly from the preview?
Modified on Sun, 27 Apr, 2025 at 3:58 AM
Hello, please refer to the following scenarios:
- Blurry Preview but Normal Output
  • Are you using a high-resolution monitor? Try enabling 'Adaptive System Scaling' in the Preferences menu, then restart the D5 client and check the results.
  • Outdated or faulty graphics driver: This issue may be caused by an abnormal graphics card driver. Please try performing a clean reinstallation of the driver. You can follow the steps in this guide: How to view and upgrade graphics card driver
- Clear Preview but Inaccurate Output
  • D5 SR (Super Resolution) may be enabled
Try turning off D5 SR widget and render the output again. For more details, refer to the article: "Why are the rendered images/output results blurry and unclear?"
  • Image viewer or configuration file affecting display
If you are using a specialized image viewer or have custom configuration files, they may affect color accuracy or visual appearance. Please try:
  • Using a different image viewer.
  • Removing any related configuration files, then check the output again.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
