Why can't the scatter/terrain grass material be generated?
Modified on Sun, 27 Apr, 2025 at 3:50 AM
Hello, please check the normal of the face in the modelling software before using Scatter/Grass Material Template in D5, as the generation of Scatter and Grass is only available for the front face of a model.
Other related known issues:
  • Currently, using scatter or grass materials on vertical surfaces is not supported.
  • Currently, it only supports scattering models under 'Nature' category; more categories will be added in the future.
  • Scattering on steep model surfaces may be sparse.
  • When using 'Select Model' to apply scatter on a model with faces that vary in height but share overlapping vertical projections, the scatter can only be generated for the topmost face.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
